any info on what type of memorycard it will have?
memorystick duo as the p800 or other type (better)?
nice to see you are posting with confidence!
MMC i think...
cheers 😉
They will come with a MMC memorycard with a capacity of 64mb
The full specification only says:
Memory
- 4 MB internal dynamic memory for phone numbers, messages, photos
- External memory on 3V MMC memory card
And there is a 64MMC optional available.
If I remember correctly I read somewhere that is was a 32 MB card. Next spring we know... 😉
I've got inside information from Nokia that it will be a 64mb memorycard.
I work for Nokia.
Then it is even better.... 😉
But why does it says under Accessories on Nokia's own spec page:
Memory Card (DTS-64), which is a 64 MB MMC?
which site is that?
on the Nokia.com site they don't have the spec of the memory card
Straight from Nokia.com:
http://www.nokia.com/phones/3650/specifications.html
check Memory and Accessories. And more on the optional memory card under:
http://www.nokia.com/phones/3650/acc_mobile.html
HTH!
Everything seems right bout this 3650 except for size... its even bulkier than 7650 and P800 ...... :cry: :cry:
Wow! This phone looks like FUN! All it needs is MP3 playback (via stereo headphone socket) using its MMC, and this has it all. Nokia are definately setting the lead in tems of handset product design at the moment. I thought SE would give them trouble but now I'm thinking Nokia is coming up with the goods. Bare in mind that the 9210i Communicator class device is 'niche' - this one definately looks set for mass appeal. It's dang kewl - 'pop'.
Sure it's a bit bigger than the 7650, but the only way to tell about size and weight is to hold one in your hand and all we have at the moment is web photos.
This could be my next phone. Maybe 😊
I have just got an email that Nokia no plans have to add the memory card with the phone.
should i trust you or not? 😃 😃
Why should you believe me?
OK that's a fair question.
The Nokia 7210 will be released with the 3.08 software version.
The Nokia 7210 is the same as the 6610 only the print from the keypad is different, only Nokia knows.
Is that a reason to believe me
