Hi all,
I used the Video application to capture some Videos, but when I tried to delete I get a message" Video: Memory full Close some applications and try again."
Although I have around 719 KB Free memory.
Regards
Hi all,
Regards
Yes, i had the same problem but i erased my problem with that Q program! 😃
It's a software bug. If you rename the file you can delete it.
Thanks for the Help, I managed to delete through SeleQ.
Regards
yes i also found this too ! i first used SeleQ to delete them but also found that renaming them to anything resulted in the possibility to delete them then...
perhaps the file you are trying to delete is being used / open / left open when you tried to delete it. This would cause some soft of sharing violation and not allow you to delete it.
yes i know exactly what you mean and this seems to be a reasonable explanation in my books...
just like if anyone uses Kazza or the like and veiws something in Theatre mode on it you cannot move the file until something else is selected to play or you shut down the application ( going off the beaten track there i know but i get you ! )
sounds like a windows error hehe
