i want to ask that wht happened if the theme are installed twice
actually i have installed many theme and later on i transfer 5 themes to my inbox
and install and 3 was alrady in my phone and downloaded twice
wht will happend now
does it take double memermory
please tell me
New installations overwrite old ones = no extra/additional memory consumption = no problem(s).
Just remove them from your Inbox after you've installed them; that's the only extra memory consumed, which you should be concerned about (and remove themes you don't really use; no point in saving those).
thanxs buddy
i was really confused......
And clear out C:/system/SKINS and E:/system/skins folders without mbm files regularly. 😊
