Remove operator logo
5 replies · 6,513 views · Started 07 May 2004
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
I want to remove operator logo from 6600 and return to the original one that phone had in original settings. Could you help ?
TheSpecialBoy wrote:Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
use seleQ or F-explore or any other
1. go to the drive c:/
2 then go to the system folder
3. then go to appliction
3 then to phone
and in that u have opt logo image in mbm format
delete it and re-boot ur phone
The complete path to the operator logos in the phone is c:\system\apps\phone\oplogo
N/A wrote:The complete path to the operator logos in the phone is c:\system\apps\phone\oplogo
So if i wanna make an operator logos, i just have to make directory c:\system\apps\phone\*.mbm ? on my seleQ ? is that right ?then .. when i wanna make the oplogos back to default , did i have to delete the phone folder?or just *.mbm only ? pls give me the information about that .. Thanks pals
Basically yes. Make bitmaps 94 pixels wide and 25 pixels high. The need to be named using the operator's country/network identification and in MBM format.
Apps like SeleQ or FExplorer do the naming for you, so all you need to do is to tell them what bitmap to use.
And all it takes for removing the oplogo is to delete the file and restart the phone.
Hi, think the name of my Operator is written in plain text exactly in the place where the Operator Logo should be...
When I change themes, the text change it's colors and the background is the color of the theme...
If I put an Operator Logo, the text goes away, if remove, the Operator name returns...
Is it really the name of my Operator or is it the name of the network I am using??
Can I change this text to my name??
