CameraFX ... problems
8 replies · 2,170 views · Started 20 September 2002
I bought CameraFX and am rather dissappointed.
Although I set the quality to "high" I cant get more resolution than 160 x 120. Am I doing something wrong? Cant imagine that it limits the pictures to 160 x 120 when the hardware is able for 640 x 480. And its a registered version - should not have any restrictions.
The screen is very slow, much slower than the original foto program. If you turn the handy it needs seconds to get the new picture. And it needs a lot more time to load and to save pictures.
And if I open an original picture (about 28 Kb) with FotoFX and save it with FotoFX without any changes, it has nearly 200 Kb!!
Any experiences with this program?
[quote="Freddie666"]I bought CameraFX and am rather dissappointed.
Any experiences with this program?[/quote]
same problem..This appl is a crap
thank heaven i didn't pay for it ;-p
regarding that disucssion about the software (cameraFX)...
,... so i gather that the camera FX software is useless? is there anything else out there that is worth trying?
Thanks very much for your reply.
will try it out.. kinda costly dont you think ? are you using it now?
seems that function wise, ti's a good software!
cheers!
