I am going to get an n-gage qd because of the "classic talking" since im going to use it as my phone. My question is how do you install .sis and .jar and others with a card reader? can i get like an in depth kind of spoonfedkind of thing since ive done nothing of the sort b4. also when yuo format an mmc card in the n-gage or n-gage qd does it autoatically make an e: partition?
n-gage qd and software installation
gygaman wrote:I am going to get an n-gage qd because of the "classic talking" since im going to use it as my phone. My question is how do you install .sis and .jar and others with a card reader?
Install a file explorer into your N-Gage, for example Fexplorer. (copy a fexplorer install sis-file into the root of your MMC and then put MMC back into N-Gage and install it from Tools/Manager.
Then while your MMC is in your card reader, copy jar-files into any folder you like on your MMC. Then put MMC back into your N-Gage, open Fexplorer, browse for those jar-files and click on them. Installation begins.
You can do it also with sis-files, but you dont necessarily need Fexplorer for SIS-files because if you copy them into the root of your MMC, they will show up in the Tools/Manager menu in your N-Gage.
