I got it installed and such, but when I try to play it on my N-Gage is says, "Data Files Are Missing, See Help For Details". Well I went to "Help" and it had nothing to show for the matter. So My qeustion is do I just need to re-install it, or is there something else I need to install.
Also, I noticed that it said in the readme file that it says that in order to enable the sound I must download a different game from wildpalm.co.uk in order to have the sound driver installed. Well... is there any game in piticular you suggest me downloading so I can get the sounds for DOOM?
Thanx a million guys!
So does anyone happen to have any ideas? I tried uninstalling and re-installing it, and still I have no luck. I just want DOOM on my N-Gage... :'(
So if anyone would help I would greatly apreciate it.
MasamuneX wrote:So does anyone happen to have any ideas? I tried uninstalling and re-installing it, and still I have no luck. I just want DOOM on my N-Gage... :'(So if anyone would help I would greatly apreciate it.
You cant install it on your mmc card. You must install it on the flash.
You'll also need the wad level files. If you want to play it on your mmc you'll need the mmc card pathc too.
When I install TForce (game with sound driver), then it says Prog. gesch. edoomexe!?
Can you german? I am just 11.
Just restart the phone after you install it. If you are using the single SIS file, and it will be proper and as for installing only to the phone I have it on my mmc. sound and all works. Have fun!!!
Where do you get Doom in a single SIS file?
kyphu wrote:Where do you get Doom in a single SIS file?
i gave the link in one of these threads which has got great sis files including doom
but i get a message realting to data files and to see help...even though its on my flash memory and not on the mmc...aany ideas??
heres the link again
[Link removed]
Here is how it works:
First you install doom (If I'm correct there are 3 sis files, the doom.sis, doomsound.sis and the mmcpatch.sis)
After that you'll need WAD files, these files are included in every Doom and Doom 2 game.
You'll have to extract them from the CD's or just download the demo and use those WAD files.
This is why Doom complains about data files, you don't have the .wad files installed.
