Is there anyway to withold my caller id
7 replies · 2,405 views · Started 11 May 2004
I've tried going through every menu but cannot find a option to turn off my caller id. Is there an update to the firmware that has this option.
If you entered the number you can press the "option" key. There should be an option there called "hide my number" or something like that. You can also dial the number with #31# in front of it (for example #31#012345680)
Delta737 wrote:If you entered the number you can press the "option" key. There should be an option there called "hide my number" or something like that. You can also dial the number with #31# in front of it (for example #31#012345680)
Thanks that worked is there a more permanant way.
well you could modify the address book entries with #31#.... I thought the operators did not implement that option by default.
liverpool lad wrote:well you could modify the address book entries with #31#.... I thought the operators did not implement that option by default.
Well the landline-operators here in the Netherlands do, so I thought maybe the mobile operators had such an option as well
Yeah, my operator will hide your number (for a monthly charge!) and even provide you with a network command to turn it on and off. It's worth getting in contact with them if it's really important to you.
djoracal wrote:I've tried going through every menu but cannot find a option to turn off my caller id. Is there an update to the firmware that has this option.
Maybee it is late but try Quickcontact from Vito http://www.vitotechnology.com That is what you need.
