Hi all
I have N-gage, working fine.
Today i just enabled its sim lock and then locked the phone. I also changed the lock code to 00000 from 12345. Everything was working fine but somehow my fried got the phone and he tried to open the lock by entering different nos. like 000000000 or 111111111 or 123456 etc in my absence. After certain wrong enteries the phone started showing a message" Lock code entered incorrectly 5 times. Code will unblock in 5 minutes."
When I came back i saw him busy with phone . I tried to eneter the actual code 00000 but it gives same message. I tried to change sim etc but eberything failed.,
It has started asking for lock code at starting and giving same message all the times. Sometimes after a little time phone shows App Start failed contact retailer.
I even tried to use *#7370# but it did not worked.
Kindly help me out of this.
I think it need re flashed by a Nokia Authorised Dealer.
Have you tried waiting five minutes and then entering the lock code,if your doesn't work,try the default one.
I have the same exact problem, except I need all of the numbers on my phone and there is no way for me to get them again because I did not save them to the sim card. Is there any way I can get the numbers?
hi i m here to help you. i can find all nokia codes
your code working know you must just wait 5mint and put your code 😉 else
i will help you. just send me your phone imei in my email (gentelmanmd[à]hotmail[dot]com )
and i will send you your code 😉
to get your imei put *#06#
if you know any one have the same probleme tell him to send me his phone imei.
good luck freind
hi
im mourad from morocco i m here to help any one to find (lock code) and to solve other problems.
i can find all nokia lock codes. just send me your imei to my email
( gentelmanmd[à]hotmail[dot]com ) i will send you your master code immédiatly
if your have other problems send me an email . i will help you if i can.
if you know any one have the same problem or other problem tell him to send me an email.
sorry for my bad english :redface:
good luck freinds :icon14:
