How can I send many files together via bluetooth to one other phone??
2 replies · 2,182 views · Started 13 May 2004
I can send one by one files to an other mobile phone via bluetooth but this is not good when i want to send over 10 files.How can I check the files for sending,and send them all together???
If you use the file manager, navigate to the folder where the files you want to send are kept. Tap in the box to the left of each file you want to send - this should put a tick in the box. Then go to the file menu and choose send as.
Though, remember, the P900 uses the phone's internal memory to send files via bluetooth. So, if you are trying to send multiple MP3's of JPG's, you may find you run out of memory!
