new firmware organizer R5B02
14 replies · 6,216 views · Started 13 May 2004
Mmmm.... i dont know about this update.
Since i upgraded i can not connect to gprs anymore...
I have done a master reset on my phone still no luck.
Keep getting a 'activation rejected' message.
ried wrote:R5B breaks voice dialing with the HBH-200 Bluetooth headset. :icon13:
This happened to me for my last update. After checking the setting once more, I realized that all the "voice tags" for my contacts have been deleted, thus causing the voice dial to stop functioning. When I re-record the "voice tags", voice dialing works as it should.
Maybe you could check to see if that is the cause of the problem
this has been discussed earlier, voice tags are not deleted, but they are not Backup(ed)
as when you do your backup before updating, voice tags are not saved in the backup file, therefor the restore won't get them back, and you have to record them again! 😉
You two are exactly right - thanks!!! I forgot about that! :redface:
No other problems here, everything looks good.
Actually, one thing I did notice. With the new firmware, when I check my e-mails, if the GPRS connection is not on when I select "Get&Send" then it will automatically disconnect the GPRS immeadiately afterwards rather than waiting for the current timeout period of for me to disconnect it manually. Which is particularly usefull if you are checking with the flip closed, 'cause there doesn't seem to be a way to force GPRS to disconnect with the flip closed.
Read on Esato forum about release R5B02 :
This looks like an important update
Fixed:
MP3 ID3 tag issues.
Crash when copying mp3's
player crashes when saved folder is not "all"
Bluetooth will now show version after master reset
Bluetooth fixes
Emergency number fixes
Bug when opening and closing flip quickly
Many MMS fixes
SMS Fixes
Network signalling fixes
SIM Fixes
Phonebook fixes
Phonebook/Sim fixes
Calendar fixes
Many Java fixes
PC Sync fixes
Memory stick fixes
SyncML fixes
Browser fixes
User Interface fixes
Jotter fixes
Localization fixes
System crash fixes
System reboot fixes
Many More Fixes....
Well we just had a certified SE service center do all the upgrades you mention here.
Since: no more GPRS (which worked fine before the update), no more iSync (which worked fine before the update), no more BT connection possible (which worked fine before the update), supportpages on the P900: cannot connect any longer (phone reboots every 3 minutes since the update).
We had these P900's for 6 days now and seriously, this is the most expensive joke on the market today.
We're doing everything possible to have a refund on both phones!!
It took years to get me from Nokia to SE, and now, I remember why!
Jeroen De Backer
Brussels, Belgium
After the update did you do a restore.
My golden rule for upgrades, DO NOT RESTORE. You change the oil on your car, do you then put the old filter back in??? Nope.
You say the service centre done the upgrade for you, when you got it back did it have everything on?
First try a master reset, then install all your apps again. I have a sneaky thought that all will work again.
dannyoneill wrote:After the update did you do a restore.
I actually have had no problems with the new update. That said, I noticed nothing has noticably changed either... visually or performance-wise. Of course with SE's helpful release notes there was no way to tell what had changed. For all we know they simply could have fixed a couple of spelling mistakes in the help file and upgraded the version number for "political" reasons.
I updated twice, the first time I did a restore with no problems, then the second time I did not do a restore, with no problems. I keep all my apps on the duo so no need to reinstall them all over again.
Regards,
Bateman
When we got it back, we had to reinstall everything but the Opera browser, all other soft was gone. I'll try the master reset then.
Could you try to connect to http://3gpp.telemak.com and play any 3gp or mp4 file in the VOD section. Packetvideo still keeps telling about the 'kernel 3' error. Any suggestions there (on upgrading the PV? I tried their website, but... only available on fine cell phones :s)
nick111 wrote:new firmware organizer R5B02 ready to online update !
P900 Phone - R3D011
P900 Bluetooth - R5D
P900 Organizer - R5B02
P900 CDA - R5A07
SonyEricsson
For me, update checking telling that 'R4B03' is the latest version. My CDA is 162004/8 R5A01 - just confused.
SD
