Opera 6.20 Upgrade - how to
3 replies · 2,533 views · Started 14 May 2004
I am a 6600 owner that came with Opera software already installed. Opera has just announced the 6.20 upgrade. Does anyone know where to get it from (I assume for free), since the only option in Opera's site is "buy". And how to install it?
stsalkit wrote:I am a 6600 owner that came with Opera software already installed. Opera has just announced the 6.20 upgrade. Does anyone know where to get it from (I assume for free), since the only option in Opera's site is "buy". And how to install it?
You should be able to download the file from opera, transfer the file using bluetooth and when it asks if you want to upgrade 6.10 to 6.20 say yes.
The Upgrade is free..
You may also need our serial number from your original copy.
Andy
BTW the new version seems to be a lot better than 6.10
rlfannet wrote:You should be able to download the file from opera, transfer the file using bluetooth and when it asks if you want to upgrade 6.10 to 6.20 say yes.
Andy
You won't have to enter your reg code if you upgrade fm 6.10 to 6.20.
You won't even have to enter it if you uninstall the old version first.
But u might ask Opera for your key anyway just to have it ready if you format your MMC one day.
Send an e-mail to [email][email protected][/email] and provide them all the info you will find here: http://www.opera.com/support/search/supsearch.dml?index=746
Regards,
Hi ozzy_1971,
Thanks for the top tip about asking Opera for a reg code for the Opera browser on a N6600.
I have been trying to find a way of asking for a week after accidently deleting it from my MMC.
I got my code within 30 mins.
Jamil.
