bluetooth problem HELP
4 replies · 1,095 views · Started 14 May 2004
I just bought a usb bluetooth adapter and installed all the necessary drivers and software but when I tried to use it it couldnt find my 6600!!!!! What should I do??
thanks in advance
btw my usb bluetooth adapter is a dongle (whatever that means :? ) and it uses the widcomm drivers, itried the serach engine but so far all the explanations are a bit technical or vague can anyone do a step by step for dummies 😃 thanks
i have read that you should install your bt stuff befor your nokia connection things, i cant get my nokia stuff working but i can drag and drop with bt so all is not lost
draz1k wrote:i have read that you should install your bt stuff befor your nokia connection things, i cant get my nokia stuff working but i can drag and drop with bt so all is not lost
could you like do a step by step on how you made it work thanks
i cant get mine to work mate that what i said, so i use the blue tooth software that came with it to drag and drop files on my fone.
