hi everybody !
i just download a directory of theme from Internet and want to install it in phone.
I copy whole directory theme in Memory Stick Duo by card reader. But I don't know file to run to install it !
Plz help me !
THank you very much !
how to install theme for P800
The P800 does not support themes. The closest you can get is to buy tracker which will allow you to change skins.
as Bassey says, Tracker skins (.ztr) are the best you can do at present. Combine them with Magic Themes from www.Symbianwave.com, and your P800 is starting to look different.
tip: buy Magic Themes now ($15), and when magic themes pro comes out (in 2 to 3 weeks I hear), you'll get an automatic upgrade. Why do I say that? Cos the pro version will support .utz files (yes, P900 themes!) 😊
Or u can download it here.
removed and banned for posting warez.
