6600 firmware
3 replies · 2,361 views · Started 15 May 2004
3.49.2 is my firmware on my n6600 and i wanted to no if it is free to get a firmware upgrade and if so how i would do this ? as i want the ETI camcorder prog, also whats the website where i can buy this as i cant seem to be able to find it thanks. 😊
leave the software as it is.
Eti Camcorder en 3gpp camcorder pro produce movies with a video quality that is worse than the standard prog.
And the new software won't let jou send ringtones, sis files or jar files true bleutooth or IR to another phone unless you rename them.
If you want the new software see if it is free, overhere you have to pay for it and if you have to do also just bring it in with a Software problem, then it will be replaced for free 😉
Grtz,
Mark.
*#0000# will display current firmware, i want to use ETI as it has unlimited video capture with sound but the firmeware must be updated b4 the sound will work apparently.
