Help! Problem on Nokia 3660
1 replies · 2,099 views · Started 16 May 2004
Hello,
My phone is Nokia 3660. My problem is when Screen Saver is active it pops up this message :
App. closed
sSaverUi
OK
It happen all the time when screen saver that display Date and Time. I already try to restore Original Phone Setting but the problem always happen. What should I do? I really appreciate your help. Thx.
Regards,
Yan
Hi! I think once you encounter that message, try to exit some application by pressing the menu key for 2 or 3 seconds and youll see the pop ups on the left side.. that is the open application. once you see these application, simply press the circle key and then press the exit key... last youll see the MOBILE icon.. just press exit and thats it ok?
if you need help.. email me at [email][/email]...
ps: you have to close the application properly by pressing the exit key...(",)
