difference between 9210 and 9210i real player
4 replies · 3,183 views · Started 16 May 2004
hi
well after almost going through many of the posts, I want to clear out few doubts.
1. what is the difference between latest 9210 and 9210i real player?
2. the quality of 3gpp is better then .rm or not?
3. is there a dual headset for nokia 9210.
thanks
djxyas wrote:hi
thanks
what is this, already two days and no body knows the answer of the above questions common mate please answer......... i am waiting.
as nobody is answering the above question, i would like to ask one more question also.
How much 9210 communicator can accomodate MMC card. Can i use 256mb for it. if anybody has tried please post your reply here.
regards
The MMC really depends in the manufacturer, the majority of the people here can work normally with 128mb MMC cards, some claim to have used 256mn and 512mb MMCs in the communicator...
Myself i only tried once a 256MMC card and id didn�t worked, so i only use MMCs up to 128mb....
TMK not a great deal of difference between the realplayers although the 9210i is rebadged as realOne player. 3gpp I don't know much about as tmk they don't work on the 9210, you need to use NIM or RM. No dual headset as there is only mono output. If you do a search you will find a thread I did on how to make your own adaptor to plug a standard set of headphones in.
