Can not download on certain theme. It shows " Installation error. Series 60 skin support 1.00 is intallaed. This component only works with version 0.0".
How to have skin support 0.0. What is different for both?
Skinsupport 1.00?
Which "certain theme" is that, exactly?
Which phone do you have (Series 60 Themes only work with the 6600; or 6620 or 7610, but those two phone models are not available yet)?
I use Nokia 6600. It is quite strange. Initially I though my 6000 has problem. Then I did re-intalled "mushrooms theme" now it does not work. and shows the message as I mentioned. Eisntein for example also can't.
