have prob with eti camcorder. Can u help me out?
4 replies · 7,022 views · Started 18 May 2004
I have a problem with eti camcorder. i've downloaded it and when i tried to install it, a warning appeared 'file corrupted'. But i cannot remove it as well. do u have any ideas what i have to do? Shall i reinstall it? I need a fine version of eti camcorder. Pls help me out.
I had the same problem with some software I downloaded...if you really want it gone you might have to do a full format which will delete all your settings and return your phone to it's orginal state...to do that it's *#7370#...... or if you download it again it'll ask you if you want to replace the current installation.
Use winrar to unzip the file U have downloaded on PC. U will get .sis & .txt file. & install using unzipped .sis file. & enjoy.
hi
I am expereincing some problems with eti-camcoder. When ever i try to play the file it crashes. Saying media application gallery close. when i tried to shift those file to my computer through pc suite. it says not able to move the file beacue eithr it is read only file or corrupt file. or write protectd file. Cananybody will be able to help me because i want to save those file. urgent
thanks in advance:redface:
hi ,
i am facing problem with eti 2 in my nokia 3230.I used eti for couple of days after that whenever i open eti it asks for input key.can anybody pls help me........how can i find the input key
