When using the calendar I am trying to set the default mode to "month view" in the settings. However, every time I exit the app and reopen it the default has been set back to "day view".
Am I doing something wrong ? How can I solve this ?
timmer wrote:When using the calendar I am trying to set the default mode to "month view" in the settings. However, every time I exit the app and reopen it the default has been set back to "day view".Am I doing something wrong ? How can I solve this ?
You need to do it via the "parameters "entry and then select "Month view". You have three different choices. If you do it via option & select it reverts back to the entry which was set on "parameters".
Rgds
did u installed games? i forgot the games name , i believe it's rally something, it's car racing games,
uninstalled it, if u don't have the games then i am not sure what's the issue.
shchiam1978 wrote:did u installed games? i forgot the games name , i believe it's rally something, it's car racing games,That's with games using the Mophun game engine; they/it has a bug that empties the calendar.
N/A wrote:That's with games using the Mophun game engine; they/it has a bug that empties the calendar.
Tat and Rally Pro and Spycall....
UnInstall the Culprit, SpyCall. Ur calendar will then work fine.
After removing, dont forget to restart the phone
same topic here as well:
rally pro erases to-do too....
