Using the supplied MMC card in a card reader
3 replies · 2,690 views · Started 19 May 2004
I'm trying to read the contents of the Nokia supplied 32MB memory card with a USB memory card reader, but it's not appearing in Windows Explorer, even though it works fine in the phone. Is the card faulty? :?
It should work. Perhaps the reader or its drivers/software (if any required) is faulty?
I had some dodgy experiances with a couple of card readers which usually ended up in the data being lost and nothing ever at any point showing up on the reader. got a bluetooth adapter. works every time now i'm used to the quirky way it works..
