3650 no network / no signal
11 replies · 6,819 views · Started 19 May 2004
Hello. I have this really annoying problem with my 3650. About 2 weeks ago i installed psiloc baby phone, the version with the uninstall problem. i fixed it by doing a full format on the phone. after that, few days after i noticed my phone does not authenticat on the network anymore.
if i change sim, another network, it goes online. if i change back to my sim it does nothing. if i change network selection to manual it finds all the networks in my country but when i select the home network it says : "no access" at it goes back to standby screen. i don't know what to do. can anybody help?
Does that SIM work in another phone? If not, the problem is with it and not the phone & you should contact your operator.
Yes the sim works in an other phone. So it is definetelly with the phone. Does anybody have any ideeas?
I have the same problem!! If anyone has an answer, that would be great!
Wirelessly posted (Nokia3660/1.0 (4.57) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Baby phone is still installed.?You uninstall that.See with file explorer what is the network in options, if you r having.Try other sim of same network.If it works ur operator for new sim with your old no. Telling that ur sim is lost or telling this problem as it is.
i have tried several sims and they all do the same. They go on-line, the network apears on screen and then it dissapears. Sometimes it has network but i can't initiate any calls because it disconnects them. Going to a service center is out of the question. Is there really no one who had this problem and fixed it?
There is no forum magic that can fix a hardware problem, which this seems to be.
I don't think it is hardware because the phone worked for about half a year without any problems.
myx wrote:Hello. I have this really annoying problem with my 3650. About 2 weeks ago i installed psiloc baby phone, the version with the uninstall problem. i fixed it by doing a full format on the phone. after that, few days after i noticed my phone does not authenticat on the network anymore.
myx wrote:I don't think it is hardware because the phone worked for about half a year without any problems.
And then it broke. It happens.
You better check your network selection within the phone setup.
Thank you for your assistance ppl. The phone is a gonner. I got myself a 3660 😊
