Help Anyone Pls.
6 replies · 1,589 views · Started 20 May 2004
im using
v3.30
28-08-2003
NEM-4
PQI 128MB MMC
im having problems evertime i play mp3's or AAC my installed program icons are gone even after closing mp3player. Is there any workaround aside from restarting or backing up my data to mmc? will firmware upgrade fix this?
even after playing mp3. i even wait for 5mins for my MMC to refresh but still no icons of my installed programs. i either restart or create a backup to mmc for my icons to appear again.
Wirelessly posted (NokiaN-Gage/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Pausing the music should be enough to bring back access to the card.
If you want to play musioc while playing games then just start the game, pause it and open up fexplorer. Then just start ur music by clicking on the music. Be warned though, this did crash my phone the first few times i did it and still occasionally makes it crash now.
you dont get my problem. if i copy mp3 files to my mmc and play it after quiting the mp3 player the shortcut icons of my installed programs (fexplorer, smartmovie, etc) are gone i have to restart my phone to make it appear again. is there any workaround aside from restarting? will firmware upgrade solve this? or does anyone here have the same problem?
my firmware is 3.30 using PQI 128 MMC
I sort of get the same problem - Not sure if it's after using the MP3 player though. All of my games are in a folder on my desktop called (strangely enough) "Games" & every so often they disappear & re-appear on the desktop individually. and I have to move them all back again.
