Hi there. Can anyone please tell me how can I view and edit Excel and Word documents on my P900? Please
I tried to copy a Excel file to my P900 but it doesn't want to copy.
First of all you need to put the excel or word file in media\document on either the internal memory or the MS Duo. Once there, you can open the standard installed app called "Viewer" and your files will be there! However, you can only view them.
If you want to edit the files, you need this app
http://my-symbian.com/uiq/applications/applications.php?fldAuto=491&faq=2
If I may add, with quick office (the link given above) you can edit and add new data to the excel sheet but there is no freeze feature yet so it can be difficult to keep track of long coloums of data
PJMani
Thanks. I will have a look at the software. 😊
There are two ways to read Excel on your P800 or P900. One way is to go to http://www.mobl.com/software/uiq/ and purchase MS Excel for Sony Ercisson. The other way is purchase Repligo software from Handango.com which allowes you to convert your MS Offices files into a readable file format on your Sony Ercisson.
Hope this will help
Piesang wrote:Hi there. Can anyone please tell me how can I view and edit Excel and Word documents on my P900? PleaseI tried to copy a Excel file to my P900 but it doesn't want to copy.
Or the THIRD way is to just use the in-built viewer as Delta737 says above(?)
