I'm new to the whole smart phone thing so pls bear with me.
There's an application(Applications/Tools) on my 3650 that can install or uninstall software, but doesn't seem to work when I copy softwares onto my mmc and try to install them using the application. Do I need a data suite (I bought a bluetooth adaptor) to do this?
Any reply would be much appreciated.
noob wrote:I'm new to the whole smart phone thing so pls bear with me.There's an application(Applications/Tools) on my 3650 that can install or uninstall software, but doesn't seem to work when I copy softwares onto my mmc and try to install them using the application. Do I need a data suite (I bought a bluetooth adaptor) to do this?
I think it will not work on just putting your softwares on the mmc because you needed to change the file name such that your software can be accessible by the phone. you can try this because i already done this and it works. for example you have a software that has an ext. of *.sis, make another copy of it and change that sis into jpg. then put it in the image directory of your mmc. then create a new e-mail(go messaging>create new message>e-mail). press option then insert the image (software) you want to install(the one that you had changed earlier). your phone will able to read the data and press option then press open. your phone will ask you if you want to install the file and of course press yes. voila. by the way if you have not configure your email, fust put anything on it. the point is that you just want to install your file ryt!
navime wrote:I think it will not work on just putting your softwares on the mmc because you needed to change the file name such that your software can be accessible by the phone. you can try this because i already done this and it works. for example you have a software that has an ext. of *.sis, make another copy of it and change that sis into jpg. then put it in the image directory of your mmc. then create a new e-mail(go messaging>create new message>e-mail). press option then insert the image (software) you want to install(the one that you had changed earlier). your phone will able to read the data and press option then press open. your phone will ask you if you want to install the file and of course press yes. voila. by the way if you have not configure your email, fust put anything on it. the point is that you just want to install your file ryt!
Thanks! That's more help and info than I hoped for
Hello Everyone,
I am a newbie here and here's my predicatment.
Somehow since last few days whenever i start the application manager on my 6600 i see only 2/3 applications over there.earlier i used to see my themes,games or applications which had got installed.but now only 2/3 of them are there.even when i install a new application it doesnt get updated.only a few times it does update it with a new application.because of this i am unable to remove any applications i have installed.apart from this all my applications work fine.
i am worried.what can i do?
Also i am sorry if i seem to have posted in wrong thread..i am kind of new at this and learning.
thanks in advance for any help
:? dee
well i think you can remove your application in app manager in your tool. im not sure becoz in my 3650, i can see all my installed software there. i think you can remove the program on your cel. 😉
