do someone ever tried using miniGPS? what benefits can I bring to me when I have this on my phone?
miniGPS
Im using it a lot, my database is really huge for all north greece!
however, i dont have a lot of C++ skils to make a programm which
exports the collected cells to a PC and add cells manually!
the calls are collected into a database file into your phone,
using 2hex characters for CELL-ID, 2 hex for Area-ID and unicode for the cell name
well can you verify what other benefit that I can get with this program.
navime wrote:well can you verify what other benefit that I can get with this program.
It pretty cool, based are where you are at in the GSM network, it can perform some simple tasks (message or change profile). For example, maybe at point A you want to use the silent profile, Mini GSM will recongnise you are in the point A area and automagicaly change the profile for you.
HTH
Didjit
