First question:
I've a Ngage and I want to delete some memory on my device, not on my card.
I do not know what to do, help.
Second question:
How can I directly bluetooth a program to my MMC card in stead of sending it to my device?
I've a Mac computer.
Thanks in advance.
Chander
Holland
You can't delete memory (unless you take the phone apart and remove the memory chips (note: it will void any warranty and also make it rather difficult to use the phone, too). 😉
If you want to free up phone memory, then:
- Uninstall programs you don't use (which you have installed in phone memory).
- Delete messages you don't need.
- Delete sound files and images you don't need.
- Delete the logs (or make the log duration shorter).
- etc.
You could also try apps like Space Doubler or Stacker:
http://my-symbian.com/7650/applications/category.php?fldAuto=11
Second question: You can't (the N-Gage has disabled the option of moving the Messaging store to the memory card; that's because if you did that & put in a game card instead, there would not be any place for new messages to go).
Does the USB cable work with a Mac?
