Multiple alarms on 6600
1 replies · 1,984 views · Started 21 May 2004
I'm currently using psiloc system tools to set more than 1 alarm (built in clock application can only be set to ring once).
I don't want to whole long path of creating an agenda note, but the system tools api seems somehow buggy. In some cases, if you press the RED button while an alarm is ringing, the notice gets away but the ring still goes on, and _it_can't_be_stopped_ 😞
Is there any other applications that can be used instead of System Tools?
esumengen wrote:I'm currently using psiloc system tools to set more than 1 alarm (built in clock application can only be set to ring once).
Yes, get a trial of 'Psiloc worldclock pro' and try this one.
