Does anyone know if it is possible to set up an animated gif file as wallpaper (and of course have it animated)? Thx.
Regs.
Regs.
Not as wallpaper but u can set it as a screen saver.
However, using an animated gif like this for your wallpaper or screen saver will drain your battery charge fast and is not worth the effort.
In addition, the backlight will be off after a few seconds which makes the animation pointless (if u leave back light on, battery drain will be worse).
u can use the psiloc screen saver for your gif screen saver
but then u have to forget battery life
as in the above post it very much true
but if u r not worry abt battery life u can use it
try it
www.psiloc.com
You can set it as a wallpaper using SmartProfiles from www.symbianware.com
