App manager in6600
5 replies · 2,366 views · Started 23 May 2004
Hello Everyone,
I am a newbie here and here's my predicatment.
Somehow since last few days whenever i start the application manager on my 6600 i see only 2/3 applications over there.earlier i used to see my themes,games or applications which had got installed.but now only 2/3 of them are there.even when i install a new application it doesnt get updated.only a few times it does update it with a new application.because of this i am unable to remove any applications i have installed.apart from this all my applications work fine.
i am worried.what can i do?
Also i am sorry if i seem to have posted in wrong thread..i am kind of new at this and learning.
thanks in advance for any help
dee
I was facing the same problem. It is probably due to some application corrupting the system. I downloaded and application called FEXPLORER which acts much like Explorer on your PC using Windows OS. Go to www.symbos.com and type "file manager" and that will get you to that file or one simlar to it. You can use that to delete applications you don't want and other very cool stuff.
Wirelessly posted (Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Awesome dude wrote:I was facing the same problem. It is probably due to some application corrupting the system. I downloaded and application called FEXPLORER which acts much like Explorer on your PC using Windows OS. Go to www.symbos.com and type "file manager" and that will get you to that file or one simlar to it. You can use that to delete applications you don't want and other very cool stuff.
Thanks awesome dude.I do have file explorer..But when i try to go to a specific folder in e:/install the program closes out.even efilemanager does that in same folder.This started happenin since the problem i mentioned.
i have install and purchas 4 appliction
now i directly contact the software supplier for the new key of the latest vesion
its happening with
i am really fed up from this
please help
they all have given me new key
and now when i wan to remove the old version
of try and buy like Ulead M STYLE, Photographer,Zipman,Quickword
and APPLICTION KEY MANAGER
when i unstall the above app
it says CLOSE ALL APP?
IF I SAY YES IT MINMIZE
IF I SAYS NO THEN IT CANCEL
now when i open minmize app manger
then it reappear again
i format my card
then install the appliction
but still the prob repeats
Vicky wrote:i have install and purchas 4 appliction
its happening with
please help
i format my card
its happening with
please help
i format my card
If you're getting new keys and you have all the codes for your purchased software, but your phone is still hassling you like that, why not just soft-format the phone. You back everything up, but even if you lose your data on the phone you have your codes for installing/activating your apps. If you're bothering to format the mmc you may as well start from scratch (and test things as you install).
