Hi!
I have a serious problem: the calendar keeps forgetting the entries.
It's like this: I enter a meeting, save, it's fine and dandy.
I exit the calendar and open it again, and the meeting's gone! 😞(
Oh btw I can't set the default view to week view in settings, the
situation's the same as above....
This is under V2.5.
I guess a fw update would work but i can't affod it in the next
couple months 😞((
Is there a way to get it working? (apart from installing a calendar app 😊
Gabor
Have you installed any games lately? Some games use the Mophun game "engine", which has a bug that deletes the calendar entries. I don't know if it has been fixed yet.
i did install a game which uses the mophun engine...
i removed the game and now it's ok 😊
thank you!!!!!
gabor
if u install and run actve desctop in the background before running rally pro, the calendar will be busy and tata=>no entrys deleted
..but u HAVE to remember to run a.d. in the background
and...u should restart the phone after playing.. 🙄
