True Type font install?
1 replies · 2,978 views · Started 25 May 2004
First of all, all I wanted to do is to read asian fonts (Chinese & Japanese in particallar) website in a P-900.
I checked SE site and they only have european language support under their language support package. (funny, knowing that they have a P-908 for asian region).
Next, I did some googling on the subject and it idicated that Symbian support TTF and there is a piece on the next forum for Nokia communicator about how to install it.
So is there anyone out there know if you can install TTF in a P-900?
Thanks in advance.
--ken
You can install TTF fonts without a problem..
But there are two problems:
1.Most applications even don't take into account that you might have some other then default fonts installed and simply get lost once you do
2.Even if you do install ttf fonts your app/webbrowser/whatever needs to recognize them/use them... which might not be the case
I would advise you not to install TTF fonts as it doesn't work well with Opera browser and you might end up with chinese fonts on english opera 😊
To be honest Opera is the only program i know that gets crazy after installing ttf fonts (ie it starts to use different size/style of fonts instead the standard fonts)
