this is crazy - wonder if anyone knows - I'm trying to sync my p800 with outlook 2003 and it's always maxing out my laptop processor to 100% by the outlook.exe process!!!!!!!! and the synch mode seems to get stuck in the analyze phase
p800 outlook 2003 sync gets stuck in analyis mode
MrHotCoffee wrote:this is crazy - wonder if anyone knows - I'm trying to sync my p800 with outlook 2003 and it's always maxing out my laptop processor to 100% by the outlook.exe process!!!!!!!! and the synch mode seems to get stuck in the analyze phase
Anybody with sound ideas?
Thanks,
P
OK - I thought it was a problem only with my laptop - I have exactly the same problem...hmm. Sorry nothing constructive to post. But will keep surfing the net for a solution. If I find I one I will post it here....
I dont think that P800 works with Outlook 2003 does it?
There is a setting for conflicting items........ try to set thse and check if you can manage to sync...... Also check that the sync station is well installed, I had a problem were the sync station driver was corrupted check that too........
First let's find out if outlook 2003 by itself is not getting stuck. Open outlook and close it again; do still see an outlook icon on the active section of the start bar? I found out at in my case that winfax ver. 10.02 freezes and really screws up outlook closing. When I removed winfax outlook works fine.
