[FONT=Arial Narrow]undefined[/FONT]Is it possible to connect a 6600 to TV to watch video ?
6600 to TV
sony007 wrote:Is it possible to connect a 6600 to TV to watch video ?
lol 🙄
elton wrote:lol 🙄
So I take it that means no 😮
elton wrote:lol 🙄
So i take it that means no 😮
elton wrote:lol 🙄
You can plug the phone into your tv/video or satelite using the built in Rca sockets under the battery.
Sorry mate,i couldnt resist.
What do I need to buy m8 or use to do this?
There is a set top kinda box from Nokia thta allows viewing of photo's on a TV screen, but not sure about video.
http://www.nokia.com/nokia/0,,54739,00.html
Ian
There is really nothing that you can buy in order to do this in existence today. Elton's reply was a joke.
You can record a TV broadcast and convert it to a video streaming format and put it on the Internet video streaming server and then connect to it with the built-in Real Player or other streaming video program.
Or you can record and convert to a file you put on MMC and view that way.
If there was a video streaming app that worked over Bluetooth, and a TV that could encode streaming video and send it over Bluetooth, that'd work, too, but there is no such TV by any manufacturer (nor the corresponding phone app).
coolice wrote:There is a set top kinda box from Nokia thta allows viewing of photo's on a TV screen, but not sure about videoIt is a device just for storing and viewing still photos from the phone on the TV.
Yes, you can want TV on your 6600.
Put the 6600 down on a coffee table with the screen up.
Turn on the TV.
Now position your head in such a way that the TV images reflect from the 6600 screen.
(It helps is your couch and coffee table is aligned and of similar height for you to lie down).
two things: a computer with tv-out capability & RemoteS60 software
-pete
cmatthee wrote:Yes, you can want TV on your 6600.Put the 6600 down on a coffee table with the screen up.
Turn on the TV.
(It helps is your couch and coffee table is aligned and of similar height for you to lie down).😃
Diagram illustrating alternate way to have TV on 6600:
[FONT=Courier New]
|***TV***|
|6600|
--- Flat Surface ---
[/FONT]
