Hi all,
I am new to symbian. I am trying to execute an example but getting the following error:
C:\Symbian\6.1\Series60\Series60Ex\helloworld\group>bldmake bldfiles
BLDMAKE ERROR: ERROR: CPP.EXE Failure
I have installed code warrior UIQ2.1 for Sony P800 and Symbian OS v6.1 SDK for nokia 3650 and I am getting the same error for both.
For P800 example i am adding @UIQ_21:com.symbian.UIQ as an argument to bldmake bldfiles.
Also I am not able to use 'devices -setdefault @UIQ_21:com.symbian.UIQ' to set the default device. It gives me an error: unable to access devices.xml!
Please Help me out :? . I have tried to reinstalled the Codewarrior but the problem persists.
Gaurav Jain
I have now the same problem with bldmake bldfiles failing because the cpp.exe crashes. Any suggestions and known fixes?
ANybody find out the cause of this?
i as facing same problem related to building files as u faced before and posted at forum(I attach ur text posted at forum at below of my text).
so please suuugest me the solution....
my id is
[email][email protected][/email]
WBR
Maneesh sharma
Gaurav Jain[/QUOTE]
hi,
I'm working with nokia 9500 communicator.
Im trying to read IMEI using MOBINFO api.
while compiling the cpp file ( impln to read getIMEI from mobinfo - jni )
it prompeted to set default device id and
I am not able to set 'devices -setdefault @Series80_DP20_PP_SDK:com.nokia.Series80
for the default device.
the xml file is in sdk root and also set the path,
did u resolved the pblm when u had this b4?
i cud not resolve the error. if u cud figure it out, help me with the solution.
thanks,
regds,
buvana
maneesh sharma wrote:Hi,
BLDMAKE ERROR: ERROR: CPP.EXE Failure i as facing same problem related to building files as u faced before and posted at forum(I attach ur text posted at forum at below of my text).
my id is
WBR
Maneesh sharma
Gaurav Jain
[/QUOTE]
hi simar here
i am also facing the same problem and when i compile the hello world program them error comes EPOCROOt not contain a drive letter.WAT to do
reply at:
buvaneshwarin wrote:hi,
the xml file is in sdk root and also set the path,did u resolved the pblm when u had this b4?
thanks,
regds,
buvana
[/QUOTE]
Hi gaurav simar here i am also getting the same error
and i did one thing
SET epocroot=\directory then cd<file dstination where u hav hello program>
then bldmake bldfiles
but error comes
epocroot must exist in existing directory.
u try this and if successful please help in my problem
i am using sdk of series60
mail me aat
gauravj116 wrote:Hi all,I am new to symbian. I am trying to execute an example but getting the following error:
Gaurav Jain
hi all i am working in borland as u have made the imei no.cpp please tell me the steps how to work in this ,rather i am having the code for this but not getting the way to make application for this in c++ mobile edition.
simar wrote:hi simar here
reply at:
[/QUOTE]
Hi i am simar i am also a new user to symbian and i am making the application using Borland c++ mobile edition ana when i enter the group of mybuild application using command line tool then i write bldmake bldfiles but the same error comes and this is because of the emulator i think see when u on ur epoc command is it runningand ur bldmake.pl is wrte in the sdk and if u find any solution do mail me
at [email][email protected][/email]
Hi i am simar i am working on the
BLDMAKE ERROR: ERROR: CPP.EXE FailureI have installed code warrior UIQ2.1 for Sony P800 and Symbian OS v6.1 SDK for nokia 3650 and I am getting the same error for both.
Gaurav Jain
Do you have cygwin installed on your machine? If so, the crash could be due to an incompatible cygwin1.dll that comes with the nokia sdk. Just rename the cygwin1.dll file in C:\Symbian\7.0s\Series60_v20\Epoc32\gcc\bin to something like incompatible.cygwin1.dll.
That should fix it.
Hi...I donno whether u guys find out the actual problem or not but that "CPP.exe" error is only for non-admin users. to run bladmake command u need to have administrator privileges or atleats Superuser priviliges.
