Ok, I'm not imagining this, every day, my P900 decides to turn back the hands of time and I'm constantly resetting the time by an hour. Has this happened to anyone else? How did you correct the problem?
Thanks again...
Thanks again...
Does it happen when you sync it with your PC? The problem could be lying there. If this is the case you should disable "syncing" the time between the PC and the P900.
Do a search, there are a lot of other threads on this. Multiple solutions drifting around on the forum 😃
