3rd party programs and mac
2 replies · 1,746 views · Started 26 May 2004
infomark wrote:I would like to install agendus on my new P900 but I'm a mac guy, How do I do it? Thanks 😮
How do you usually sync your P900 to your Mac ?
I think the only possible way is to use Bluetooth. I usually sync mine with iSync and bluetooth, but havent tried installing files.
You can try sending the installation file to your P900 via bluetooth.. and just run the file on ur phone.. when its done installing, just delete the file.. i havent tried this, but i hope it'll work
In your application>utilities folder there is an app called Bluetooth File Exchange, run it anddrag the file you want on your P900 onto it icon.
Simple as that 😊
