new mmc card
5 replies · 1,313 views · Started 26 May 2004
i just gota new mmc card for my 6600 and ive lost all my applications and stuff includng opera!!! how do i get them back
thanks
dilema wrote:i just gota new mmc card for my 6600 and ive lost all my applications and stuff includng opera!!! how do i get them back
thanks
The applications is on the mmc card you got with the 6600. Download a app called zipman and zip the programs (if it dosen't work to send without zipping), and send it trough IR or BT. You can also use a mmc card reader for your computer.
Good luck😊
Put the old MMC back in the phone. They're there. If you want them on the new one, too, use either a PC-based card reader to copy the old files to the PC and then to the new MMC, or PC Suite's backup/restore.
i cant find the files in zipman and i am using my last free try before buying on my original mmc of zipman
dilema wrote:i cant find the files in zipman and i am using my last free try before buying on my original mmc of zipman
Try what N/A said... Use the Nokia software and do a backup of your old mmc card.
AeroX
i tried to try that (if that makes sense) but i cant connect to the pc wth com ports and when i use bluetooth the pc suite doesnt think its connected
this is driving me insane and ive only been trying for 3 hours ,im now considering carring 2 mmcs with me all the time and just switching them around every time i need them
