I've been using this SMARTMOVIE for a while, but now all of a sudden it keeps on pausing any video file after about 10sec and coming up with 'App Closed Audio Decoder !. I haven't changed any setting in conversion which had worked b4, i'm trying to play the same video files which I watched b4 with no problem. I'm using version 2.04. Anyhelp on this would be appreciated...
my phone is nokia 6600, using the default firmware !!
sony007 wrote:I've been using this SMARTMOVIE for a while, but now all of a sudden it keeps on pausing any video file after about 10sec and coming up with 'App Closed Audio Decoder !. I haven't changed any setting in conversion which had worked b4, i'm trying to play the same video files which I watched b4 with no problem. I'm using version 2.04. Anyhelp on this would be appreciated...my phone is nokia 6600, using the default firmware !!
i got the same problem, can anybody help? Has anybody used another codec than xvid? this my work i guess ...
i have the same problem as wel
but if u open the file straight away u shud hav no problems at all
if u take too long to open the file tht message wil appear
Opening a xvid movie in gallery works but if you open another one after that it will crash. so i would recomend you play the videos directly from Smart movie.
