I am trying to backup my phone to the PC using the software with it, but it keeps giving me an error when I press the backup button. It says "an unexpected error has occurred while backing up data." Please run backup again. I tried again and again and nothing works. I even uninstalled then re installed and still same error. Can someone help???? Please!!!! 😡
Help with PC Suite for Nokia 6600
dudejee wrote:I am trying to backup my phone to the PC using the software with it, but it keeps giving me an error when I press the backup button. It says "an unexpected error has occurred while backing up data." Please run backup again. I tried again and again and nothing works. I even uninstalled then re installed and still same error. Can someone help???? Please!!!! 😡
Did you close all apps in your phone?
No apps in you PC are trying to use the same port as your N6600?
Lenepyhe wrote:Did you close all apps in your phone?
it is happening bcoz ur one of the file is not copied by pc suite that is why it is saying
if u want to backup do one thing
back up ur phone in MMc and MMc with the card reader in pc
i will sujest u that remove ur mmc and make backup on ur pc via card reader.
and backk up only ur phone without mmc with pc suite
u mainly have contacts and calednder note
then format ur set. conect it with pc suite
restore onl contacts and calender(put tick on it)
then install the old mmc and it will work
but the application u have installed will demand u the key
which u have got on the purchase
i was suffering from the same problem
i have post a thread also by the name " unexpected error" u can check it.
