Help!!! How To Install Themes? 3650
3 replies · 9,667 views · Started 27 May 2004
well, i tryed installing via a irda dongle...
basically i installed the .sis file onto my 3650 via nokia pc suite and the irda adapter BUT!!, no change is made on the phone, if i check in the tools --> App. Manager --> i can see the file and it says its installed....
but/....the main screen is the same and no change is made?
also i need help as to where the .sis is to be stored?
i get these options using nokia pc suite:
NOKIA 3650:
* PHONE MEMORY:
- Installation and java files
- Other Files
- Sound Files
- Video Files
* MEMORY CARD:
- Image Files
- Other Files
- Sound Files
- Video Files
where do i install the .sis? , whereever i try to install it, it alwayz goes into the app manager? but the theme is not shown....can anyone please help? :?
The 3650 runs Series 60 1.2 and does not support native Series 60 2.x (6600) themes.Try sLauncher and search the forum.
sun007 wrote:well, i tryed installing via a irda dongle...
NOKIA 3650:
* PHONE MEMORY:
- Other Files
- Sound Files
- Video Files
* MEMORY CARD:
- Image Files
- Other Files
- Sound Files
- Video Files
I am having the same problem on my 6600. I transfer the theme to the phone using the Nokia suite supplied with the phone, and it does indeed send, but then I cannot seem to install the theme into the themes folder. It says it's installed, but then I can't find it. I have searched the forum and this is the thread I found.
Help would be greatly appreciated.
Thanks!
******Problem now solved******
Themes say they are installing but cannot then be found in the themes folder where I expected them to be. Simply create new theme or edit an existing theme, then when you go to select your wallpaper you will find the new theme is here. Also when you select your icons you will find the new icons here. Select them and it works fine.
