I'm trying to get my P900 synced up with both my notebook and my desktop PC. Desktop PC is running Outlook 2002 and everything works and syncs fine.
However when I try to sync with my notebook over bluetooth, all get synced except the calendar entries... To be more precise all my P900 calendar entries gets wiped out! Has anyone seen this? I'm running Outlook 2002 SP1 on my notebook... I've reset my P900 already and I also archived Outlook and started from scratch already...
Thanks,
Ken
I have the same problem, using Office 2000. Everything synchs, except my calender.
kenliu wrote:I'm trying to get my P900 synced up with both my notebook and my desktop PC. Desktop PC is running Outlook 2002 and everything works and syncs fine.
However when I try to sync with my notebook over bluetooth, all get synced except the calendar entries... To be more precise all my P900 calendar entries gets wiped out! Has anyone seen this? I'm running Outlook 2002 SP1 on my notebook... I've reset my P900 already and I also archived Outlook and started from scratch already...Thanks,
Ken
I've tried to get this working, but there is a post on the Soney Ericsson site stating that the sync software will only work with 1 computer only.
I have a bigger problem at the moment where it currently wipes out appointments in my 2003 when just syncing with the one computer, Any idears?
Hi Guys,
I finally got it working and the solution was closer than I thought. Just go to control panel -> Internet Options -> Programs Tab and ensure Outlook is the default Email client. And voila, it works! Both on my PC at home and with my Notebook. The solution is actually documented in SE knowledge base....
There's an option in outlook itself to choose Outlook as the default client, but that had no effect.
Good luck!
Ken
Unknown wrote:I've tried to get this working, but there is a post on the Soney Ericsson site stating that the sync software will only work with 1 computer only.I have a bigger problem at the moment where it currently wipes out appointments in my 2003 when just syncing with the one computer, Any idears?
