I'm looking for an app that gives me an easy way to open a lot of the programs I use often instead of having to find the app through the menus. Is there such a program thats any good. it would be cool if i could then assign that program to a soft key and be able to acces it that way.
Is there a program that does that (or something similar)?
A
You can move all the program icons you want to the top of the menu,so you dont have to find them everytime,or create a new folder and move all the app icons into it and place this at the top of the menu.
There is also a program where you can use the joystick and assign shortcuts to left,right,up,down,but i cant remember the name sorry,its here somewhere (search the forum).
The program your thinking og (possibly) is 'Psiloc Task Manager' excellent little program. cantryout an purchase here:
http://www.psiloc.com/?id=prod&nrp=37
hi
if u have many downloaded appliction and wants to add them in ur fav / go to
download demo of STACKER
from http://www.symbianware.com
it will say that app is not comatable
but its works fully
i am using it
and by using this u can add them too ur go to menu.
