i have had my 6600 for about 2-3 monthes, its realy good and i only have problem the battery it runs down so quickly(about 1-2 days)
i havent got any progs running in the background and i dont realy want to buy a new battery having just spent �45 on a couple of new 128Mb mmc cards
help please
Battery Optimization
I wouldnt have thought that in 2-3 months you need a new one unless it was defective from the start.
The BL-5C battery is very cheap (around �4 from e-bay"Buy it now"😉 and always available.
personinneed wrote:i have had my 6600 for about 2-3 monthes, its realy good and i only have problem the battery it runs down so quickly(about 1-2 days)
help please
I found having bluetooth on when i wasnt using it drained my battery quite quick-do you do that? Also try and empty it completly and then charging it for four or five hours. Li-Ion batterys sometimes benefit from this
thanks very much both of you
andrewn wrote:I found having bluetooth on when i wasnt using it drained my battery quite quick-do you do that? Also try and empty it completly and then charging it for four or five hours. Li-Ion batterys sometimes benefit from this
The bluetooth issue is correct.
But the drain and charge method is not, Li-ion batterys do not need to be drained and charged,in fact keeping the battery highly charged can actually increase the overall battery life. (This was stated by the manufacturers when Li-ion batterys were first introduced).
For more info on this subject search the forum as there has already been a LONG discussion on this.
My bad im getting my batteries confused. Li ion dont have 'memory' issues so no need to do that... :icon13: for me
