How do i change the background picture of "Go To"
5 replies · 3,019 views · Started 27 May 2004
Its all in the title really i just can't seem to work it out and this dog sniffing another dogs bum is starting to annoy me...
And can i add create a new text message to go to?
Go to Menu/Themes/ then click on the theme you want to "Edit" Then choose Image in 'Go to'. 😊
You cant Enter new message in Go to but you can assign it as a soft key.......
Ps Even if you could add it to Go to this would require MORE button pushes than if you move your messaging icon to the top of the menu. 😊
Attachments: New message.JPG
I got to that menu but thn it gives me options like Default, user defined, theme 1 etc How can i make it one of my pictures? User defined is those stupid O2 dogs...
andrewn wrote:I got to that menu but thn it gives me options like Default, user defined, theme 1 etc How can i make it one of my pictures? User defined is those stupid O2 dogs...
This sounds strange cause when you choose 'User defined' the 'Select memory' option should pop up first and after choosing the memory (Phone or Memory card) you should be able to browse your folders for pictures and to choose whichever you want...
Doesn't this menu appear on yours at all when you click 'User defined' ?
ozzy_1971 wrote:This sounds strange cause when you choose 'User defined' the 'Select memory' option should pop up first and after choosing the memory (Phone or Memory card) you should be able to browse your folders for pictures and to choose whichever you want...
No reply to that one andrewn???????
Did you just realise?????????? lol 😃
Yeah that seems to have sorted me out now... I go to choose this time. It wasnt just me being stupid though honestly! I changed it to blank and then back to the dogs just by clicking on user defined again. I really did!
