New: Mobile Database Viewer
1 replies · 4,737 views · Started 28 May 2004
Mobile Database Viewer allows you to view your MS Access, Oracle, FoxPro, dBase, MS Excel databases on your phone. It also supports any ODBC compliant database. You can view he database, apply queries and search for keywords.
Author Notes:
Database Viewer for Sony Ericsson Mobile devices has features which helps you to become mobile with your database. You can view the records of your database tables in grid of rows and columns or one at time. You can apply queries on database to filter PDB contents. You can write SQL Select query to create pdb having contents of two or more tables based on relationships.
Features
View MS Access, Oracle, FoxPro, dBase, MS Excel and Any ODBC Compliant Database.
Apply filters, Sort Orders or apply any SQL Select query to get database contents.
View database tables: all at a time or record at a time.
Easy browsing: By considering the Mobile structure, we provided very easy navigation facility. All operations can also be performed via numpad keys on Mobile.
Search records for keywords within a database
