File explorer
3 replies · 3,368 views · Started 29 May 2004
Is it possible to send the apps. And games using file explorer.Ifso i think we should send from both app. And installs folder.Is it right?In apps.All components of app. Suchas .aif .app .caption.rsc etc have2 be sent individually?Please answer
yes you can send files from FExplorer, how ever you should send only the install file (i.e. if you recevied an installer for example a SIS game try to save it first to another folder which the explorer can retrieve later, then install the received file from the inbox folder. therefore if you want to share it with anyone use the saved file not the install one.)
That means i cant send any installed files from my phones.Only files that i have saved just before installation when i downloaded or recieved from pc can be sent.Am i clear.Tell me sir.
