I have just bought a 6600 and installed supplied 32MB MMC and Belkin card reader. The phone reads the card fine, but when I put it in the card reader the file manager (Windows Explorer) doesn't recognise the card ("Please insert card"😉. I installed drivers and still no dice. I even saved data to internal memory and formatted the card with the phone. Any tips??
MMC/Card Reader Problem
please change the brand of the card reader
i purchase the mmc card reader my MMc does not work on it
but when i purchase 7in 1 or 10 in 1 it working fine on it
rest i don't know more
but this was my exp.........
thanks for your tip Vicky, I am going to pick up a bluetooth dongle and 256MB card tomorrow and might as well grab a decent reader while I'm at it 😃
isischild wrote:I have just bought a 6600 and installed supplied 32MB MMC and Belkin card reader. The phone reads the card fine, but when I put it in the card reader the file manager (Windows Explorer) doesn't recognise the card ("Please insert card"😉. I installed drivers and still no dice. I even saved data to internal memory and formatted the card with the phone. Any tips??
Try Renaming your card (you can use the same name) on the nokia in memory
if that doesn't work
Check to see if your card reader allows you to hotswap it while a card is in. This may work (insert card then insert reader to computer) but check the manual b/c some machines don't handle mass storage usb hotswapping well.
