hello
i have ultramp3 installed on my 6600 but it cant read mp3 that i transfer by IR port plz help me 😃
mp3 by IR port
tarik_s wrote:hello
Have u tried the RESCAN file system command?
What Id do probably is to use file manager and compile the mp3s to the MMC and Run UltraMp3 to rescan the system. Maybe that'd work... 😃
if you transfer the files with PC suite it has option automactli to convert files to wav. did you turn that option off??
1) cut off the .mp3 extension
2) transfer thru pc suit
3) use fxplorer to rename that file to .mp3 and then search for files tru ultra ..
hope that helps in the worst come conditions 😉
cheerz
i got a nokia 3660 and i want to put ultramp3 player but i cant find it anywhere
so if any body can send the software for me i will aprictiate it this is my email: [email][email protected][/email] :icon4: :icon4: :icon4: :icon4: 😡
TEAMDEATH wrote:i got a nokia 3660 and i want to put ultramp3 player but i cant find it anywhere
If you're looking for warez, sorry not here. Anyway you could always try the demo version... http://www.lonelycatgames.com/files/ultramp3_s60.zip
