Nokia 6600 MMC Format
6 replies · 24,720 views · Started 29 May 2004
I just did a format on my Nokia 6600 becasue when i recieved a message, it would'nt show their name but it would only show the number. I did a format and this did'nt resolve the problem.
After doing this my MMC card is asking for a Unlock code. How can i format this using a Bluetooth dongle?
Any suggestions please?! Thanks..
u must have put the lock code/password in mmc
and now when u have format the set it will demand u
u can not format the mmc with bluetooth
u need card reader
there are many post on this topic find them.
But when i got the MMC i did not set a password on it? Its default i mean i cannot remember setting a password for it. Anyways if i was to use a Card reader to format it, would it be ok?
Formatting the card in a card reader probably won't help. Or at least it didn't help me. Or anyone else I've spoken to about it. As far as I know, to stop it asking you for a password, you need to use a nokia 9210, and do a forced erase on the card.
Someone on here said:
"This problem can be solved by this way :
1. You need a Nokia 9210.
2. You need an unlocked MMC (can be borrowed from your friend)
3. Put the unlocked MMC into the memory slot of Nokia 9210.
4. Choose the command that will format the MMC (unlocked MMC)
5. When the fone ask you to confirm the format order, quickly remove the unlock MMC and put in the locked MMC which you want to unlock.
6. Press Ok.
If you're lucky, the locked MMC will be formatted and the password will be also break. Good luck !"
Haven't tried it myself yet, but I'm planning on it as soon as I can get my hands on the 9210!
